3M to 2N gearbox?
Zollie
3M to 2N gearbox?
Beitrag von Zollie »
Hi
I put a CY engine in my 1982 passat 2-door.
I changed the gearbox from 3M to 2N, so the ratios are better for a lighter car ;) Can I keep the same speedometer in the car? Will it show the actual speed, or will it be different??
ergo: Is a 1800 speedo different from a D/TD speedo?
Re: 3M to 2N gearbox?
Zollie hat geschrieben:ergo: Is a 1800 speedo different from a D/TD speedo?
No,all 4 Cylinder Front wheel drive have the same speedo.
Only 5 Cylinder and syncros have a different speedo.
Greetings
Zollie
okay thanks
