Clutch: 190 / 210 / 228 mm ?
Zollie
Beitrag von Zollie »
Hi
I am having trouble with my 210mm clutch in my 32b-TDI. It's slipping!
I think the clutch is too cheap, because the old 190mm worked perfect.
My question is, do the 215/228mm clutches of the 5cil models fit the 4cil flywheel? They both have 24-teeth, but how about the flywheel?
hope to find out soon, I really need to replace it with a high quality one!
Thanks
Re: Clutch: 190 / 210 / 228 mm ?
210mm is the biggest one for 4 Zylinder frontwheeldrive flywheel.
Please search for a stronger clutch or Taxi clutch.
I have a 228mm Clutch in my 1,8t modification Passat. You need a flywheel from a 4 Zyl. Syncro and a Custom made Gearbox.
In the normal Gearbox is not enough space for the bigger Clutch and pressure plate.
Bye Manni
Zollie
Okay thanks!
I am now using a LUK 210mm. Have not taken it out yet, I gues the pressing plate is too weak. This was a 70 euro Ebay clutch.
How can I find a taxi clutch?? That would be 210mm but stronger? What is the brand I should look for? Sachs? My kfzteile preishammer 190mm clutch worked better on this engine!!! I think that's strange :)
Search on ebay? Or where? And only 32b / audi 80? Or also Golf 2 etc??
In holland a 210mm will cost you around 175~190 euro in the shop... A part of the hobby is not to pay prices like this :occasion5:
HI,
i am sorry, but a good clutch cost good money also :notworthy:
Sachs is good.
Go to your parts dealer and ask for a stronger one.
Price is round about 200,- €
Bye Manni
Zollie
Manni hat geschrieben:HI,
Sachs is good.
Bye Manni
My 190mm from KFZteile24.de was better than this one :D I thought LUK was okay?
Buying a Sachs on ebay or in the shop differs 100 euro, is an ebay Sachs not good? Or is it too old or something?
Zollie
http://www.ebay.de/itm/ORIGINAL-SACHS-K ... 2897wt_982
This should be the Sachs 3000 098 002 that I need, it's the 210mm.
Price seems good, better buy this one, or one from my local shop that asks 200E... ?
